Hinge broke off from screen
Hi,
I see how to replace a hinge, but it doesn't appear that the hinge is broken. It looks like the hinge broke off from the LCD screen. Here is a pic, I hope this works... https://www.dropbox.com/s/2nlkg36332yrxr...
My brother-in-law gave me this to try to fix after my niece with autism was a little rough with it. I was going to order new hinges and the clutch cover part, but I don't think that will help. The hinge broke off from the screen. I do not know what part that would be and I can't find a way to replace it. I am guessing that the whole display unit may need replaced.
Thanks for any advice or leads.
3 Comments
Hoz, take a look at this answer How do I replace broken left screen hinge
Hoz, hope your dutch is decent. Check on here
by oldturkey03
My dutch is non-existent! Thanks oldturkey03. I think I can do the steps necessary. However, I am trying to avoid replacing the whole display. I need to replace the part that the hinge connects to on the screen. The hinge itself seems fine, but it broke off from the display part. I don't know if just that part can be replaced or the whole display. The computer works fine.
by Hoz
I do not think that you will have to do that. It definitely looks like your hinge is broken, but if you look at how it mounts to the display, it appears like changing the hinges should work.
by oldturkey03
