Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
107 Questions View all
How do I attach a replacement battery?
3 tiny male connectors stayed attached to the old battery, therefore i need to know if i must solder? glue? or somehow attach the battery cable to the board to make a permanent connection
Score -1
Add a comment
1 Answer
Most Helpful Answer
Assuming you don't break your display while detaching the battery from the display assembly, you will need to de-solder the original battery from the logic board and solder on the replacement.
Hope this helps! Good luck!
Score 1
Add a comment
Add your answer
ken will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 354
