The Sony Xperia Z is an Android based phone that was released in 2013. It is one of the largest phones of the Xperia family with a 5-inch full HD display. Model numbers include C6603/C6602.
98 Questions View all
putting my antenna back into my xperia z
I Took my phone apart and replaced the screen. I can not figure out if the antenna was mounted or loosely fit and attached on both ends. im looking for some form of visual to see how it goes into place. I have googled and youtube my issue. Thankyou
Score -1
Add a comment
1 Answer
One part of the antenna fits on the upper motherboard, on the right side.
The other end is on another motherboard part which is located inside of the bottom "unit" where the vibrator/external speaker is located. You have to bend back the clasp (lightly, don't break it) and remove the motherboard piece to reconnect it easily. It is possible to reconnect it with a fine pair of tweasers, however, I find it easier to remove the piece, connect the antenna and put it back in.
Hope this helps!
Add a comment
Add your answer
Derek will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,959
