Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Black screen, ribbon cables intact, battery OK, restored
my iPhone (used only as iPod, no cell service) has a black screen nearly all the time. Occasionally, on pressing Home or Power buttons, active screen appears. Shows as working when connected to my MacBook via iTunes. I recall 2 or 3 occasions before this when screen was black when I thought the phone was on; this may be the relatively sudden advance of an earlier-begun "disease." I have so far reset it (no help) and restored it--twice. Still (almost always) black screen. Between restores, I popped the back, removed battery, and unhooked and rehooked all the easily accessible cable connectors (they all seemed snug when I pulled them). So I had the battery out for that time. Most I've seen of the screen was when it came on during/after the first restore, and looked normal while it lasted. Doesn't flicker or distort, just goes black. Battery, last checked, seemed to hold decent charge, so I'm suspecting deeper trouble. No major drops that I'm aware of. Saw a YouTube vid about a black screen repair job where someone replaced battery, then some other part, neither helped, then the "digitizer." What's that and could that be the trouble? And worth the repair. I'm comfortable going in again to replace parts. Thank you!
Score -1
Add a comment
1 Answer
Sounds like a faulty display just because it has had no major drops doesn't mean the screen cant go bad.. Replace screen and see if that fixes it
1 Comment:
So you mean this part?
Product code: IF182-003-1
Could it possibly be a bad battery that isn't reporting charge accurately? (Well, it's a cheaper fix anyway!)
Thanks!
by
Add a comment
Add your answer
jamminactor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 125
