Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Question Closed
Won't charge replaced charger and battery
Hello,
I have a IPhone 4S that won't charge.
I have replaced the battery and charger port.
And resetted the full iPhone with itunes
Is there anything I can do more?
Sorry for bad english.
Add a comment
1 Answer
Most Helpful Answer
Glenn Ongena, since you already changed teh battery and the dock connector you should check all the charging components. This could be caused by a failed/damaged charging coil. Check for any physical damage, or if you have the knowledge and tools, check for function. You want to start by checking 3 inductors. For that, of course, you need a multimeter, or at least an ohm meter, to check for continuity. I hate to refer to those as fuses, but they most certainly control part of the charging circuit. First one is reference designator L3, it is a FERR-120-OHM-1.5A inductor. L4, right below it , has the identical value. Next would be the charger inductor L28 2.2UH-1.8A-155MOHM. All of these are pretty much available at mouser. com or digikey.com. Check the Diode D604, located just above L28. Hope this helps, good luck.
Score 2
3 Comments:
Thank you for your detailed comment.
L3 and L4 are good. L28 I need to remove the metal protector. Before I do that, if L28 is broken. Is it possible to fix it? And I mean by a normal person. I have ICT and ectricity degrees.
by
YEs it is but will require decent tools and good soldering skills (hot air soldering preferred:-)
by
oldturkey03 thank you for sharing such detailed knowledge.
by
Add a comment
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 170
