The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Questions View all
Samsung Galaxy S4 Active won't charge after new port?
I changed the charging port but the phone still will not charge. Anyone have any idea??? I also changed the screen due to the fact that the screen was cracked. It won't even turn on or anything. Help :)
Score 2
Add a comment
1 Answer
Most Helpful Answer
I would make sure that you have tried using different cables to charge it because cables go bad over time. If you have tried new cables then I would try assuming that the part is bad and return it and try another one. If the new part does not work then it is probably an issue on the motherboard.
Hope this helps!
Score 1
Add a comment
Add your answer
Alyssa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 997
