The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3534 Questions View all
Why won't phone stay on unless plugged in?
I dropped my phone and it broke the display. I replaced the LCD and it is now working fine, except for the battery is constantly reading 100% but the phone dies very shortly after being unplugged from a charging source. I have cycled the battery and reset the phone completely, is there a chance something on the charging port is causing this, or will this end up being a logic board problem?
Add a comment
Chosen Solution
New battery should sort your problem out
Score 1
Comments:
It worked, thanks!
by
Add a comment
I agree with this answer and only wish I had found it earlier, as I had the same or similar fault, mine started with the apple logo going on and off, and going into restore mode didnt help and constantly failed. This fault then went on to the phone only working when plugged into the charger, it did however boot normally but went off again as soon as it was disconnected, so obviously a battery problem would be a good guess. I purchased a new battery and the phone is now working as it should. A final word of warning though, having charged my other new phone with the same charger I got the flashing apple logo, luckily removing the charger and rebooting the phone sorted it, I would recommend not using the same charger again because it nearly destroyed my other phone as well. A new charger is cheaper than another phone.
Add a comment
Add your answer
Jack will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 25
Past 30 Days: 116
All Time: 2,934
