The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying.
914 Questions View all
started dissambling ipad 2, now worried
its the wifi-3g model
im still in the process of trying to remove the screen
http://s17.postimg.org/3kfrk01db/IMG_002...
when this happened !
http://s29.postimg.org/5zhf7pi7b/IMG_003...
looks like a peice of metal sticking out... scared me
what is it? have i ruined it... do i just push it back in?
i thought the atenna is more near the home button
anyway wifi still works, home button still works so everything seems ok at the moment, tempted to call it a day and take it to the shop... still need to know what it is tho
Update
seems i was worried about nothing, it was little bit of metal poking out from me scraping the case with the pry tool
http://s12.postimg.org/5y0evmhfh/IMG_003...
i think if i tear this plasticy thing all around the edge then the job will go along alot quicker, got to be careful tho because i think i pushed alot of it into the ipad during the start
forgot to mention im sick of watching youtube videos.. gets me nowhere lol but thanks
Update 2
i understand now, i guess the damage is already done to the bezel so i may aswell continue with my unorthodox method.
ill have to order a new one, i dont consider them cheap myself
i thought i was doing it wrong at the start but it was literaly the only way i saw possible, o well
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
Hi there it seems you have pryed between the metal frame and plastic bezal you need to pry between the glass and plastic.
The iPad screen is a trick enuf repair go look at some videos and reevaluate when your doing..
Add a comment
You are scraping the metal case off. Pry between the glass and the plastic bezel. In fact it is okay to even destroy the bezel and put the new one on since it is so cheap.
Add a comment
Just be careful with the wifi and power button antennas and flex cables very very easy broken.. Just a heads up the videos will show you the locations
Add a comment
Add your answer
soya will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 74
