Model A1213 / 8, 16, or 32 GB capacity
216 Questions View all
My iPod touch wont turn on at all and its fully charged
My iPod touch wont turn on at all.I tried connecting to computer and it syncs and it makes that noise when you connect your iPod to computer but the iPod doesnt turn on at all.I thought it wasnt charged but my computer tells me it is fully charged so I dont know why it doesnt turn on. I did connect the iPod touch to a cassete input to hear my music in my big stereo. It played like three songs and then it turned off and from there on it didnt turn on even when i charged it and connected to the computer.What should i do is there a solution?
Score 5
1 Comment
I had this problem im pretty sure, with me i spent 2 days on finding out what is it by following error codes but i finally got to down to error code 1 which is hardware malfunction i belive and with that im pretty sure there is nothing you can do about it except get it fixed by a professinal.
by
Add a comment
Chosen Solution
It sounds like you have a bad battery. Use this guide to replace the battery.
Score 4
Add a comment
Most Helpful Answer
I had the exact same problems you described:
try this it worked for me,,,
when connected to itunes, hold down the home and sleep button together for 10 seconds, this should restart the iPod and the apple logo will appear,thanks
Score 18
15 Comments:
THANK YOU THANK YOU DAVID.I thought I would lose it! Then it was revived by this David's-Ipod "CPR".
by
thanks david that worked for me hold home and sleep down for 10 seconds
by
If the iPod connects to iTunes and can sync without the screen ever turning on then your problem is most likely your screen. There's a guide here on how to replace it. Gook luck
by
OMG DAVID THANXS SO MUCH!!!!!! u saved my ipod it worked!!!!!*SQUEEL*
by
do you reset your ipod when you do this
by
Show 10 more comments
Add a comment
Just hold down the sleep button at the top and the home button at the bottom. Wait ten seconds and then it should restart.
Score 3
3 Comments:
Works perfectly. It helped mine because it just did it.
by
I held it for 30 seconds and it turned on! Thanks so much!!!!!!!!!!!!!!
by
Thank you it worked yay!
by
Add a comment
(Ipod 5 generation 32gb). My ipod 5 won't turn on (Black screen) But it keeps making a beep sound like its on but nothing nothings on the screen??? The screen is black but it makes no noise?? Do I take it to a professional to see if it still works???
Score 2
Add a comment
mine didnt work
1 Comment:
any other options
by
Add a comment
https://www.ifixit.com/User/237403/Amand... what u should do is hold the home screen button and the lock screen button and see if it turns on ur charger might be broken this happened to me. Everyday I tried to turn it on and I couldn't get it on I left it on the charger for four days then at my basket ball turnament I told my friend and she said that if I push the home button and the locks teen button that it might work and what do u know it did plz contact me back if it worked for u
1 Comment:
what if your home button is broken
by
Add a comment
my ipod screen jus went blank/black...its did this many times and i just go straight to holding the sleep/wake button and the home button but funny story my home button is broke and i've took this thing to a shop to fix the screen but they did a lousy job(rushed) so maybe thats the problem? i can hear the charging sound when i charge it and it has charged overnight so can someone please help me out here i have no other options
Add a comment
Add your answer
Amanda Tarin will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 4
Past 30 Days: 14
All Time: 22,571
