With the exception of the game console itself, video game accessories can be anything from the controllers, memory, power adapter (AC), audio/visual cables, and more.
131 Questions View all
How to fix just x-axis of right analog?
My Xbox 360 Wired Controller right analog's x-axis is not working. I have checked the potentiometer that works on the x-axis. It's not changing resistance as the one for the y-axis or the two others for the other analog stick are. When I connect the controller to my pc and run x360ce, it shows an initial value on the x-axis and then it reduces to zero without taking any further feed back. When I clear the axis and reassign it, it automatically picks it up. So what I am saying is it has an initial value that is getting picked by the app. Then it reaches zero and refuses to change again.
How can I fix the potentiometer? Or is there something else I should check first? I have opened up the controller.
2 Comments
It looks like the potentiometer is giving a very small immeasurable change in resistance.
by
I am having the same issue. Do you have any fix as yet?
by
Add a comment
1 Answer
Most Helpful Answer
Sherjeel Shabih, the only way to repair this is by replacing the analog stick.
Score 1
2 Comments:
I have some old playstation 2 analogs lying around. Will they fit? They seem to be the same. Is there a way to check the resistance range on the potentiometers without connecting them to a supply? Or someway to do it with an external supply?
by
I do not believe that those will fit, but of course you can try. You will not need a power source to check the resistance of a potentiometer. All you need is a multimeter with an ohm scale. https://www.youtube.com/watch?v=DJtV5PH2... good example
by
Add a comment
Add your answer
Sherjeel Shabih will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 5,212
