Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
No service or searching issue
Hi
I bought a logic board that was locked to a net work and jailbroken. I got it network unlocked and restored it.
It gets coverage in large towns but not anywhere else. I have checked connection no.7 and it is perfect also both gold prongs are touching the Bessel. The only thing I can see is on the back of the logic board, directly under the number 7 connector there should be a little gold round thing, and that is missing.
Any help would be greatly appreciated.
Update
Score 1
4 Comments
Post an image of your board with your question. This will let us see what you see in respect to "the gold round thing"
by
[image|363660]
by
Hi
I am not sure how to load an image, I tried and there is just a number.
by
The round gold thing over the first screw hole bottom right. This is missing from my board.
by
Add a comment
1 Answer
Chosen Solution
Maureen Kelly, "The round gold thing over the first screw hole bottom right" is reference designator J5_RF and it is your cellular antenna connector. You kind off need that for your phone to function properly. It is a Murata MM8130-2600 and check the datasheet for the exact part on here. Please be aware that this part is very small, it does need soldering to be replaced. You will need some great skills and good tools to replace it. Hope this helps, good luck.
Score 2
2 Comments:
Just to be sure, is this on the underside of the logic board as in picture.
Thank you for your help
by
yes, that is where its at
by
Add a comment
Add your answer
Maureen Kelly will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 168
