Repair guides and support for Kenmore washing machines.
1862 Questions View all
Kenmore 110 Washer won't drain or spin? solved
I was doing laundry and machine was working perfectly until it got to a point where water gets drained.. no any kind of sound or noise that it's even trying to do anything, water just sits there in a washer.. Any suggestions what is happening with it?
Score 3
Add a comment
1 Answer
Most Helpful Answer
Is the load balanced? Is the drain hose clear and unclogged and unkinked?
Lid Switch Assembly
If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Score 1
1 Comment:
Yes it was a lid switch issue.. it's fixed now! Thank you!
by
Add a comment
Add your answer
[deleted] will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 846
