Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
Question Closed
I've got some battery problems after change the Home Button
Hello. Soon after I fixed the Home Button, my battery began to fail. To charge it, is consumed much more time than before. The battery, which previously lasted for 6 hours, today has duration of 2 hours.
Add a comment
1 Answer
Most Helpful Answer
I would double check and make sure that the home button is seated in it's slot on the dock port flex correctly. Since it is attached to the same part of the device that controls charging maybe you have a short there. While you have it open also look well to make sure that nothing else on the dock port flex cable is shorting out. If the phone is generating more heat than normal this is usually a pretty good indicator of a short.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 54
