Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
How can I reattach the bezel screen clips (they broke off)?
The bezel clips that attack the front assembly to the rear casing broke off. Should I use a little bit of gorilla glue or is there a little trick to putting those clips back onto the bezel? Thanks!
Score -1
Add a comment
Now is it the full frame with the clips that came off the screen?
If so they yea a little bit of gorilla glue will do the trick just let the glue cure first as that glue expands and you don't want it gluing to the inside of the phone cause it's strong stuff..
1 Comment:
No, just the clips themselves.
by
Add a comment
I would buy a new bezal then because it will cause problems it's very inexpensive.
Glueing the clips on will most likely break off when trying to take screen out again
Add a comment
Add your answer
omid will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 323
