Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Can't slide to unlock stuck in welcome screen
i did
soft reset
hard reset
can connect to pc i did factory reset
i replace the digitazer and screen, still no slide
is like blind or no sensitivity at all
some one tell me replace the digi
didn't help
don't know what to do
by the way in itunes when i do the factory reset
says congratulations you iphone is unlocked
don't know if is factory unlock or what..
today i put it in alcohol i will see tomorrow
i am getting good in taking this thing apart!!!
Score 1
3 Comments:
Why are you planing on placing it in alcohol? Any water damage to this phone?
by
the water color thing is red, thats why,
by
by the way all the buttons are working good, just is not sensitivity on the phone
by
Add a comment
1 Answer
roy, there is the possibility that your digitizer is defective. Double check your work and see if everything is correctly seated. Try your new digitizer on another phone, or try another new digitizer. It is not uncommon to get replacements that have a faulty digitizer. Should it still not work with another new one, you may have issues with the touch controller IC on the logic board. This would be a major repair since it would require a reball of the IC. Hope this helps, good luck.
1 Comment:
i will try that later, we have other phone 4 with a beatyfull crack on the screen, i wil check both digis
by
Add a comment
Add your answer
roy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 6
All Time: 4,553
