Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Questions View all
Can I remove my optical drive and leave the bay empty?
Hey all,
This is my first post.
In the next little while, I plan to follow the iFix it guide to remove and clean my logic board, as it has some beer damage.
I was thinking that while doing that, I might remove to optical drive and just leave the bay empty, for weight (down the line I might install an SSD, but right now I don't have the money).
My question is - is it alright to just leave the bay empty? Are any of the connections daisy-chained in such a way that it could affect power routing or something similar?
Any thoughts/help/advice would be appreciated
Score 1
Add a comment
1 Answer
Chosen Solution
While I haven't done this my self (leaving it out), I can't see any problems doing it.
I should point out the slight weight difference is a few ounces so I wouldn't do it with the idea I was lowering the weight.
Frankly, I find an optical drive too useful to take it out unless I gain something with its replacement (putting in an SSD), thats what we use to do. Today I would just swap out the HD for a SSHD (hybrid drive) as its more cost effective Vs a dual drive setup.
Lastly, without the optical drive being in place you will likely loose the mounting screws for the 2nd HD/SSD frame. So for that reason I would put it back as getting the correct replacement screws will be difficult later.
Score 4
1 Comment:
Hi Dan,
Thanks for the advice - I opted to leave it in there for now. I am considering the SSHD setup down the line - but I'll leave that for now.
Thanks again!
Jon
by
Add a comment
Add your answer
Jon will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 3
All Time: 2,265
