Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1497 Questions View all
iPhone could not be restored. An unknown error occured (28)
iPhone 3G got wet...someone at the AT&T store put it into restore mode. When I go to restore the iPhone (per these instructions:
http://www.iclarified.com/entry/index.ph...) I get the unknown error occured (28). Any idea how to fix it? It looks like its totally bricked.
Add a comment
Chosen Solution
Looking this up the info I find says the logic board or battery (most likely the logic board) is toast. I'm afraid you are right and its bricked but would suggest you give an Apple store a chance to look at it. Ralph
One sample of the info I found. Ralph
http://modmyi.com/forums/hardware/701981...
Add a comment
Most Helpful Answer
well, ralph could be right.
but eric, i miss something in your description - there is nothing about cleaning and nothing about flashing the phone with something like irecovery.
did you disassemble and clean the phone at all???
if not - get the tools and disassemble it, clean the logic board and the connectors with ipa and a soft paintbrush, look out for odd looking stuff (white/greenish and black burnt parts)
take also care about the dock connector. a shorted nand flash could also produce errors - but that would be a little bit tougher to fix and i think you should start with the stuff i mentioned above
good luck
Score 1
Add a comment
I updated itunes and connecting my iphone 3g could not restore due to error (28) occured
Add a comment
Add your answer
erikpierson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 13,519
