Waterpump removal and replace instructions for 2003 BMW 325 ci?
.need instructions to replace waterpump on a 2003 bmw325 ci
scott, take a look on here. It's for a 325 i but should be identical for your engine. Hope this helps, good luck.
Check this out if you need a tool to remove the bmw water pump:
Friend,your water pump is not working and at the same time your car undergoes to overheat at a low engine speed or at rest position. When you start your engine,the temperature will fall. Also,you are trying to reduce the top radiator hose with the engine warmed up and running. If you find the E46 water pump to be dropping on the back of hose,you may feel pressure arises once when pressure of the hose is released. Some times there is a little drip coming from water pump housing itself. So,if the pressure is not observed then it's proved that water pump is failing and certain repair is required to the system.
One of my friend recently faced this type of problem,so you should give primary focus on following points:
(i)Fast of all,drain out the cooling system
(ii)Remove cooling motor fan conceal.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 238
