Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Why CPU fan runs at full speed?
Hi Guys!
I have a problem with my macbook.
Few months ago I replaced my spilled keyboard and after that iSight camera doesn't works anymore.
Today I decided do fix it. After disassembly I noticed that there is some deformed pins in camera/wifi connector. I fixed that and after booting my mac I was surprised - the camera works. I make a FaceTime call and camera really works great, without any problems. But later i noticed that CPU fan spins at max (sounds noisy) and CPU runs at only 796 MHz all the time. I was trying to boot with unplugged camera connector but it doesn't helps.
Please tell, what can I do with it.
Thanks.
Score -1
Add a comment
Chosen Solution
I've done all resets (SMC, PRAM) few times but doesn't succeed. Then I decided just to completeley reassemble my MBP to make sure that everything is clean and well connected. And OMG, it work fine so far. Thanks for your replies guys.
Add a comment
You should apply new thermal paste to the heat sink and stop using the laptop until you do.
1 Comment:
There is no overheating on GPU or CPU, all temps are fine. Thanks.
by
Add a comment
Sounds Like battery trouble. Is the battery ok? Did you try a SMC reset?
1 Comment:
My battery is really old and has only about 50% of health. But it's not the main problem. Thanks.
by
Add a comment
Add your answer
soldvit will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 231
