Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
Is there any way to bypass the c300 or i'm forced to replace it?
Hi
i have a similar issue i broken the battery connector and during the bypassing the second battery connector to the c300 i just went away from the mainboard
turning the iphone on seems that the audio and the wifi is not working
did i damaged the phone permanently^
is there any way to bypass the c300 or i'm forced to replace it?
thank you
Add a comment
1 Answer
Chosen Solution
franklindee, it should be possible to bridge the area where C300 was located. Even so I am not a proponent for doing so. Usually I suggest to replace the component properly, but a bridging of the solder points should work. C300 should not be directly related to your audio or WiFi.
Score 1
Add a comment
Add your answer
franklindee will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 129
