Repair guides for the MacBook.
3787 Questions View all
Service battery after cold temperatures?
Hi, I have a 2006 macbook with a aftermarket battery that I got off amazon for $20. The battery works perfectly when I leave it in warm temperatures but when I bring the computer outside (even when it is off) it looses its maximum capacity from 5462 mAh to 4021 mAh. Its factory maximum capacity was 5600 mAh.
Also, the macbook shuts off at 25% battery no matter what and it will not turn back on without the magsafe adapter.
Any ideas or explanations?
Thanks, Ted.
Score -1
3 Comments
How cold is cold?
by
from about 20 degrees Fahrenheit to 40 degrees Fahrenheit. Im in northeast ohio so it usually is cold outside at this time.
by
the battery was manufactured 12/28/13 and has 12 charge cycles on it
by
Add a comment
1 Answer
Chosen Solution
Ted Mayer, sounds about right. Remember that " Cold temperature increases the internal resistance and diminishes the capacity. Batteries that would provide 100 percent capacity at 27°C (80°F) will typically deliver only 50 percent at –18°C (0°F). The capacity decrease is linear with temperature. The capacity decrease is momentary and the level of decline depends on the battery chemistry.The performance of all battery chemistries drops drastically at low temperatures. At –20°C (–4°F) most nickel-, lead- and lithium-based batteries stop functioning. Although NiCd can go down to –40°C (-40°F), the permissible discharge is only 0.2C (5-hour rate)" from here.
Score 2
Add a comment
Add your answer
Ted Mayer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 384
