Apple released the MacBook Pro 15" Unibody, the second generation of the MacBook Pro, in October 2008 with a new aluminum upper case machined from a single aluminum block.
3092 Questions View all
2 black horizontal lines in the middle, MBP 2008 15"
Hello!
So my MBP has 2 constant black lines in the middle around the apple logo. It wont show on external display though.It boots normally. Did the pram and smc reset. Now i dont know what's next. Should i look for a display, or is there anyhing else that can be done? Help much appreciated.
Thank You!
Cameron
Score -1
Add a comment
1 Answer
Chosen Solution
Cameron H, single lines across an LCD are usually caused by TAB errors within the LCD panel circuitry. They are very difficult, it at all, to repair. I would suggest a replacement display. Of course, you want to make sure that all the cables are properly connected etc. Hope this helps, good luck.
1 Comment:
Thanks a lot. Will check cable. Hope to have some luck:)
Have a nice day. :)
by
Add a comment
Add your answer
Cameron H will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 91
