Comprehensive repair manuals for each of the six versions of iPod Classic sold from 2001 to 2014. Common repairs are battery and hard drive replacement.
2158 Questions View all
iPod frozen on: Do not Disconnect
There's no physical damage to the iPod, but the display says "do not disconnect." After an hour or so, I did disconnect from my computer.
Score 2
7 Comments
Removed 'iPod' tag, it's superfluous because the device already provides categorization.
by
i don't know it seems stuck on this display
by
the display reads "do not disconnect". it doesn't respond to anything.
by
tried your suggestion holding for 8seconds several times, still no reponse>
by
both at the same time and simultaneously neither gave results.
by
Show 2 more comments
Add a comment
Most Helpful Answer
Try resetting the iPod.
Quote from Apple Support:
"Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step."
Another Quote from Apple Support:
"Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center."
The ON setting for the hold switch will be in the direction that makes a colour visible underneath where it would not be visible if the switch was set to OFF.
My final advise would be to wait for the battery to completely drain, then charge it all the way up. Then, turn it on and see what happens
Score 4
Add a comment
thanks apple suport it works great i reseted it an now everything is fine
Add a comment
Add your answer
saw will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,163
