Laptop will not boot with batery inserted, only without the battery?
Could a bad charger cause the computer not to power on while the battery is inserted.It is odd to me; the battery is new and if I power on the laptop, it will boot to a grey screen and the fan revving high. It will not shut off holding down the power button. I have to remove the battery and unplug the charger, wait a second or two(I do have to wait a second or two, otherwise no light to indicate power),then power it back on. Once the battery is removed, it works flawlessly. I know it seems obvious to swap a different power adapter, but one is not readily available and I am trying to minimize the cost by starting with the least expensive fix. My other options are the dc/sound board, and the battery connector. I was hoping that someone else ran into a similar situation, and had some input. Thank you in advance....
Comments:
Hello
I've nearly the same Problem. My Book is only starting without the battery installed. I didn't find a solution till now.
by
Add a comment
