Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Question Closed
Device won't charge with OEM cable.
I have a customers Jailbroken iPhone 5 (verizon) and I replaced the power volume flex on it. Upon finishing the repair it was fine. Everything was working. 2 hours later he called the shop and complained that it wasn't charging and giving him an error. Now we went and bought several 2 non-apple chargers and 2 OEM chargers from the apple store. All of them gave the same error that he had at home. What could this be? No PC or MAC can detect it. We've swapped at least 5 charge ports on it and still the same results. The Speakers, Mic, Headphones and Home Button all work. Anyone have any clues.
Also I'm not sure if we can we can remove a jailbreak without being able to connect to a PC.
EDIT: I also changed the battery a few times to make sure that wasn't causing issues also.
Add a comment
Most Helpful Answer
You could go into setting and reset and erase all content and settings this should clear the jailbreak..
When removing the battery did u pry on the logic board side?
I see a lot of people with battery issures , charging issues I think the iPhone 5 must be the worst iPhone apple have made
Score 1
2 Comments:
I did pry from the board side but I went in very gently with a small tool. And be extra sure it wasn't the battery we also swapped them out.
by
Strange if you have changed all the parts then it must be a motherboard issue if you get it resolved let us no
by
Add a comment
Be sure to check you didn't damage these
Did u change the battery also??
1 Comment:
Those are intact as well and yes several times.
by
Add a comment
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 7
All Time: 404
