Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
Problems with the LCD? Negative affect when phone is tilited?
I just recently replaced my iphone 4 screen which is not the first time. I have done this repair many times with very few problems I could not solve. After the repair I began to use the phone and something seemed off with the display immediately. When you tilted the phone to the right or up even a little bit up, the colors would invert as if i had turned on invert colors. It was like an illusion. I even put the invert colors setting on and then tilted it and guess what? It would invert the colors back to the original. Its really nothing drastic because the phone is fully functional but I would like to know what could be causing it? Maybe some damage to the LCD port? Any way comment if you need a better explanation because I know this post must be confusing.
Score 1
Add a comment
Most Helpful Answer
Hi Logan there low quality screens I was having the same issue with screens I was buying so now I only buy screens with genuine lcd and don't have this problem anymore.
I have included pics to show u... If you looked at them off centre they looked negative effect even on boot screen at a angle the black screen looked white. But looking straight on the picture was grand..
Were did u buy the screen
Score 2
2 Comments:
Thankyou, I suspected this was the problem because I usually only buy OEM screens but I had a budget to maintain on this phone so i went with a cheaper one. Thankyou for your help, I'll make sure to only buy Original Screens from now on
by
i have the same problem... so you're saying that i should buy a new screen and thats the only solution ?
by
Add a comment
lava kkt3+lcd negtivb porobalom
Add a comment
Add your answer
Logan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,226
