Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
phone wont turn on
My iphone went flat as I was talking on the phone I quickly put it on charger then once it turned on it was just a black screen and started vibrating continuously for quite a few hours I took it off charger left it vibrate hoping it would die once it goes flat again it did stop the vibrating but now a few weeks later I put it on charge and there is not even any light or anything what should I do help please?
Score 1
1 Comment
Did you try holding down the on/off and the home buttons at the same time for 30 sec?
by
Add a comment
Most Helpful Answer
Try what that eman05 wrote If that does not work there could be a need for strengthening the contacts screen or the screen is burnt out and require replacement.
Score 1
1 Comment:
i've tried holding the home, on/off buttons together for 30-60 secs that hasn't worked at all?? how would I go about strengthening the contacts screen?
by
Add a comment
I would remove the battery take the two screws out from the bottom and slide the rear cover up now undo the screw in the battery and gently lift the battery connector up til it pops out now press power to drain any power that was in it for 3 seconds. Then reconnect battery and try to power up..
Score 1
5 Comments:
Thanks I Shall Try That :)
by
Think he means buy strenthing the contacts is just make sure you have them snapped in place proporly
by
Thanks I'll check it out also :)
by
Let us know how you get on you
by
I've Just received my battery today and replaced it but nothing has happened not even any light coming on or anything... Any Other Advice???
by
Add a comment
My phone turned black wheni was talking to someone and my lock button is broke. So i tried pressing the home button and it doesnt do anything. But when i put it into the charger it dings but doesnt turn on. Siri starts talking as well. It is really weird but idk what to do.
Add a comment
Add your answer
Shenika will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 183
