replace logic board with core duo?
From pics on line the isight and 2.0Ghz core duo logic boards look identical. My iMac's video ram stopped working so I need a new logic board. Someone told me I'd have to get a new LCD, but a Core duo Lb and LCD is cheaper than an isight LB?
Score -1
Add a comment
1 Answer
Chosen Solution
The logicboards are different.
never had any problems with the video ram - mostly the soldering under graphics processor are bad (both cpu generations had this problem)
the problem with those older boards is sometimes the quality - the have problems with the graphics processor and/or the capacitors are bad
Score 2
4 Comments:
there seems to be two different logic boards shown for the intel 17" - the 1.8GHz, if you look at the last pics to replace LB for both the isight and 1.8 intel they look identical down to the screw holes. Anyway, I am getting an error from AHT - ATI/1/4:113-xxxxx-113 - the video ram, right? I already replaced all the caps and nothing has changed - I suppose it is possible that I had a bad cap and then have a dry solder joint, but I think that would be a strange coincidence. Before I trash this board, i am going to try and put a heat gun to the video RAM, maybe I can remelt the joints and get it working...
by
I was reading another post about the video graphics processor going bad and displaying a checker board. This is exactly what my iMac is doing - you said you had fixed these before - can you explain how to do it ?
by
yes i did this job on about 30 iMacs. it's a little bit hard to explain - is use different tools do do that. here is a video of someone fixing the ps3 YLOD with a regular heat gun - the procedure on the iMac board is the same - i think you will find the gpu.
by
Thanks, I took a look under the video heat sink and noticed a huge amount of extra compound, some touching the surface mounted pieces - after cleaning it up, the display was perfect. Two minutes later the power died on the logic board, so now I have another problem to figure out...
by
Add a comment
Add your answer
Vince will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 13
All Time: 2,835
