Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1234 Questions View all
Is the iPhone 5c charging port the same as the iPhone 5?
I need to replace a charging port on an iphone 5c (water damage) but i cant find this part cheap! I saw on ebay a few at $100 from USA sellers and $12 from chinesse sellers!! Which one is a real charging port for iphone 5c? I've been googling if i can use a charging port of an iphone 5, but nobody is talking about the iphone 5c or 5s reparations! Unless it is about the screen! Any advise?
Score 2
1 Comment
Just buy the chinese one, Apple parts are made in China anyway.
by
Add a comment
Chosen Solution
No. The parts are different. They are visually identical from the port itself to the headphone jack, but the ribbon cable that connects to the logic board and the two pressure contact points are different. Unfortunately this makes the parts non-interchangeable. You can view both parts on the iFixit teardown for the respective devices.
Score 4
1 Comment:
Another advert ..mostly for LCD's ... A check of the two charging ports for comparisson cannot be made as I only see the charge port for 5c.
by
Add a comment
There's a difference, but it's possible.
If you use iPhone 5 charging port you also need the iPhone 5 homebutton flex, then everything will work ;)
I did already 2 iPhone 5c with iPhone 5 charging port.
Score 1
4 Comments:
I dont get it! What is the home flex? I have a 5 parts phone amd a 5c acting up. What do i need to do?
by
The home button flex is on the 5s not on the 5. Nor is it on the 5c. They both have two pin connectors where two brass tabs from the screen side press onto two "Hooks" on the case/board side. I have to try this tomorrow so I will try both.
by
Can you use a 5c logic board in a IPhone 5?
by
iPhone 5 and 5c do not home button flex as such, they have a short connector with two tabs. They don't fit into anything , instead they are "pressed" against two "hooks" when they are assembled.
by
Add a comment
The two charging ports are different. Start at the end of the flex cable. The iphone 5 has a piece cut out to fit a screw. The iphone 5C is oblong with no piece cut out. Beneath the speaker. (The square silver thing) The two contact points on the 5 are on oposite sides of the cable. The 5C has them both together .
Look at the headphone jack on the 5C it protrudes whereas the 5 headphone jack is flush and so won't fit.
Lastly is the screw Tab at the side of the headphone jack. The 5 Tab is right near the front whereas the 5c tab is halfway back. Either way you wouldn't be able to screw it down and for each you would have a screw tab in the wrong place.
Score 1
2 Comments:
by
No, I will keep it simple, the connections are different places and orientations.
by
Add a comment
can i use iphone 5s chargimg port on the iphone 5
Add a comment
Add your answer
asmodeus draco will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 15
All Time: 24,760
