Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
80 Questions View all
Transmission fluid—how many quarts to fill?
How many quarts of transmission oil for my 2005 Ranger 4WD?
Score 3
2 Comments
its a 1992 ford ranger 5 speed
by
patsymiller0, 1992 Ford Ranger 5 speed manual transmissionApprox 2.65L/2.8quarts US of ATF Mercon V, video link below will show how it is done.
Good luck.
https://www.youtube.com/watch?v=AC8lhIcK...
by
Add a comment
Chosen Solution
Raleigh, Ford says that the transmission holds 10 quarts on two-wheel drive models and just under 10.5 quarts for four-wheel drive models for a complete change.
Score 4
3 Comments:
08033530020 Mr ola
by
Four wheel drive
by
@Olayanju Suraju what make, model, year?
by
Add a comment
Uses less if you don't drain the torque converter.
Score 2
2 Comments:
Well how manny qrts is less if u dont drain the TC??
by
Generally the tc holds about 4-5 quarts
by
Add a comment
This answer was originally to another question.
According to the Owner's manual :
2005 Ranger Auto Transmission Fluid - use Mercon V
4x4 with 3.0 and 4.0 engines use 10.3 Qts (9.8L)
Note the 4x2 uses 9.9 Qts (9.4L) with the 2.3L engine and 10.0 qts (9.5L) with the 3.0/4.0 engine
Score 2
1 Comment:
2005 Ranger 4x4 with 3.0L or 4.0L engine takes 10.3 qts (9.8L)
Use Mercon V ATF
see page 233 of manual
https://www.fordservicecontent.com/Ford_...
by
Add a comment
Raleigh /patsymiller0, If a manual tranny, Ford Ranger 5 speed manual transmission Approx 2.65L/2.8quarts US of ATF Mercon V, video link below will show how it is done.
Good luck.
Score 2
1 Comment:
How many liter atf for my ford everest 2005 model automatic transmission
by
Add a comment
Add your answer
Raleigh will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 69
All Time: 55,327
