Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
Distorted sound from external speakers/headphones.
Hello!
So basically, I can't plug in external speakers or headphones anymore, as the sound will only be heard from the left speaker, with a really heavy amount of distortion that makes it un-hearable. The sounds from the internal speaker, is still OK.
I think the problem was because I plugged in a 30 watts amplifier, through the audio port, which now I know might have screwed the sound card on the logic board.
I tried repairing the disk, disk permissions, resetting the driver using terminal, etc, but nothing worked.
Is there a way to replace the sound card, or plug in another one into the logic board, or use one that can be plugged in the Firewire/ExpressCard port that could solve this problem?
Many thanks in advance.
Score 1
Add a comment
Chosen Solution
A work around might be a USB audio Adaptor - USB audio works separate from analogue audio and have mic's and line / out ports on them.
Replacing the sound card is not complicated (different models have different locations for the sound card some are on the I/O board some are on a speaker/microphone board)… but… it might be the audio jack that's cooked and that is not a DIY repair unless you normally repair computers or small electronics. De/Soldering logic board components requires special tools, solder and lots & lots of practice (it's very easy to damage a mulitlayer board with too much heat).
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
There is no "sound card" on a laptop or netbook as the audio is integrated on the logic board so if the sound output has become damaged by overload or water ingress then its a new mobo that will be required :(
Add a comment
Add your answer
Dave will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 11
All Time: 5,095
