Model A1288 / 8, 16, or 32 GB capacity
451 Questions View all
Why is my input only going through one ear on any earphones?
when i plug in my earphones it the input of my iPod Touch wont go through my left earphone. It does this with every earphone I try. if I push in on the earphone really hard it will work so that's why i know the input is messed up.
Score -1
Add a comment
1 Answer
Chosen Solution
since it works when you push it hard in the connector - i would guess that there is debris/lint inside the connector (almost a common problem)
try to clean it with canned air (careful - only air, no moisture) or someting similar to a q-tip in small - but du it carefully - the earphone jack is fragile.
if that wont work, it might be possible that one of the soldering points are faulty - you can see them here on the bottom left
replacing the part is possible, but not easy - it's soldered onto the logic board
Add a comment
Add your answer
Michael Frigon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,124
