Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Viberator and loud speaker not working :/
Hi,
just replaced my screen and everything went perfect. But after replacement. The vibrator was not responding and the sound was not working at all :/ Has anyone had this problem before? Any ideas what could fix it ??
thanks!!
Score 1
Add a comment
1 Answer
Both of these components engage the logic board with pressure contacts. The speaker enclosure contacts the dock ribbon assembly, and the vibrate motor contacts the logic board directly. It is critical that the points of contact be clean and free of oils from your skin in order to ensure good contact. Additionally, check the following:
For the vibration motor:
Make sure that both of the contacts for the motor are intact and able to reach their proper contact point on the logic board. Also make sure that the motor is in the correct position. If it is rotated a bit too far, then one contact may not be in place and it takes both of them to properly complete the circuit for motor activation. Refer to the guide here and pay particular attention to step 26.
For the speaker:
Make sure that the contacts are intact and properly positioned as seen in step 18 of this guide.
Also, as an FYI, you could use the Speaker Enclosure guide as reference for both...
Update
The vibrate motor would be the easiest to test separately. The trick of it is that you need a way to apply 0.3 volts(I think) to it briefly. You should be able to use a coin battery (like a CR 2032) and a couple of small wires.
Additionally, you could start with a multi tester to ensure that you have continuity for both components.
I'm not sure about a test for the speaker module other than continuity...
iPhone 4S Speaker Enclosure Image
Guide
iPhone 4S Speaker Enclosure Replacement
Difficulty:
Moderate
iPhone 4S Vibrator Image
Guide
iPhone 4S Vibrator Replacement
Difficulty:
Difficult
30 minutes - 2 hours
3 Comments:
Thanks for the help, but cant get any of them to work :/ I have all clips and they are all in tacked. I have tried to turn the vibrator multiple times with no effect. I will try to clean them with some alcohol and see if that works. Is there any way to test them separately?
Thanks
by
thanks have tested vibrator and it dos not work, just bought one on ebay :) have no idea how to test the speaker so bought one of those as well to be on the safe side. Thanks for the advice.
by
Hi,
I have replaced the vibrator and the speaker, but both still do not work :/
If anyone has an idea what it can be, please respond.
Thanks
by
Add a comment
Add your answer
jeppe will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 218
