Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
iPhone keeps dropping USB connection
My iPhone 3GS keeps getting disconnected from the USB port of my Mac Mini. I have tried restarting the phone and the mini as well as various other tricks found on Google.
When the phone is connected to the USB port, it gives the "charging" beep and sometimes it immediately disconnects while at other times it loses the connection after a minute or two. I have tried changing ports, using a different cable and connecting it to my PC, everything yielded the same fruitless result :(
Could anyone help with this please?
Thanks
IMZ
Score 1
Add a comment
Most Helpful Answer
If what "markus weiher" said doesn't work you nedd to buy this part:
http://cgi.ebay.co.uk/iPhone-3GS-3G-S-Ch...
Score 1
Add a comment
check the dock connector of the phone -- sometimes there is a lint inside - but there could be some fluid damage to the connector - in both cases i would clean it with a soft paintbrush - but when fluid was involved - i would use rubbing alcohol and the paintbrush
Add a comment
Add your answer
im will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 3,617
