won't power on unless unplugged then plugged in
washer will not power on unless you unplug from wall power outlet and let set about 5 min then plug back in to power and will start then
Try the following---when the washer will not "wake-up"...
1) Press the START button at each corner (north/south/east/west). If the washer CONTROL PANEL "wakes-up" reliably at any position---check the START button. Does it look crooked/out-of-position compared to the POWER button?
If so---replace the CONTROL PANEL COVER.
2) If the START button looks normal---replace the DISPLAY BOARD.
3) Tap/bang on the washer at the top/left/rear corner (without damaging the sheetmetal or paint finish).
If the CONTROL PANEL "wakes-up"---replace the MAIN BOARD (sticking Power Relay).
Please let us know your results.
banging did it - sticky relay!!!!!!!!!!! Thank you
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 43
All Time: 12,873
