Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Pression on the display: white stain?
Hi, I've repaired 2 iPhones 4 and 1 iPhone 4S and I've always the same problem, I can't understand.
The display and all stuffs look perfectly, but with a little bit more pressure than normal, there comes a white stain only for one second... Like touching the TV.
Why????
Thanks
Add a comment
1 Answer
Chosen Solution
The screen is an LCD. If I recall correctly, the images are formed by energizing a Liquid Crystal matrix. I believe that when you press on the display, you are displacing the crystals in a manner that allows more of the backlight to show through. Incidentally, I think this also indicates that your replacement screens are not manufactured to the same specs as the one that Apple uses. The glass in an OEM Apple screen assembly is frequently stronger than what is found in many of the less expensive replacement units.
Score 2
Add a comment
Add your answer
crikketto will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 74
