iPhone 4 Doesn't Charge
Hi,
I own a Iphone 4.
It doesn't charge and it isn't recognized by ITunes.
I've changed the charging dock but still the same problem ...
I tested the phone with a charged battery and it works ...
Could you help me ?
Best regards
5 Comments
After inquiry, there were splashes of water on the phone ...
by fred
I did another test : I used a charged battery --> the iphone goes on
--> ITUNES recognize the Iphone --> the symbol "charging" appears when the iphone is connected ---> BUT it doesn't charge
by fred
sounds like a bad charging coil or power IC. The coil would be my first choice
by oldturkey03
Is it easy to change ?
by fred
no, not an easy repair. It does require good soldering skills and the right tools. If you are unsure about soldering it yourself, I'd suggest to find somebody close to you that can do SMD component soldering.
by oldturkey03
