Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
iPhone 4s wifi & bluetooth can not search network?
thanks to see this post
i really have no idea
i already see many tutorials, and i already did it but nothing happened
i can turn on my wifi (not grey)
but the problem is, my iphone 4s can not search any wifi network
and the bluetooth also like that.
// i just try to search my iphone bluetooth use my blackberry
my blackberry can search my iphone bluetooth
so i think my bluetooth is fine because i can search it with my Blackberry,
(just try on thursday 2nd jan 2014)
i ask some people that can fix idevice, they say that it's because of the ic
but i have seen some tutorials, it says that i should repair / change the wifi antenna / maybe the screw is not tight
does anyone in here can help me ?
thanks so much
Score -1
Add a comment
You may need to tighten up the screw, or the grounding clip could be stuffed or you may need to replace your antenna :)
1 Comment:
i already thighten up the screw, can you send me the pictures of the wifi antenna ?..
and i want to ask again sir..
whether my bluetooth still work if the wifi antenna broken ?
by
Add a comment
Hey man this here is a photo of my wifi antenna out of my iPhone 4s.. it deffentally can't be the grounding clip because if it was you wouldnt have any wifi or bluetooth (which is my case) so i would try replace the antenna :)
3 Comments:
is that wifi antenna ?
why it's different with what i see in internet astin ?
btw thankss before
by
btw ..
can you give me some tutorial ?
is it same with this method ?
http://www.youtube.com/watch?v=m2ktb7UFT...
by
[URL=http://s392.photobucket.com/user/nevaron...][IMG]http://i392.photobucket.com/albums/pp6/n...[/IMG][/URL]
is this same with the picture above ?
by
Add a comment
Add your answer
danny will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 753
