LCD won't light up or scrolls green lines - what's wrong?
Back story on my Samsung Galaxy S4 i337M:
When I got the phone it had a broken LCD, so I refurbished my own glass/LCD combo with LOCA, and put it into the old bezel frame. The LCD wasn't adhered perfectly square onto the glass, so it tends to lift around the top, but I solved that issue by putting on a case that covers the edge of the glass.
That worked just fine for about a month. I reached into my pocket to check my phone, hit the power button, and no LCD light up - just the softkeys. I know the phone is still powered up normally because hitting the lock button lights up or shuts off the softkeys every time.
The first time it happened, I was able to get the LCD working again just by hitting the lock key over and over again, but since then has not been so easy. A battery pull seemed to solve the issue a few times, but one battery pull resulted in green lines scrolling down the screen. It's at the point now where most times a battery pull won't even solve my problem.
My LCD is not damaged. I checked very well. I even scrubbed the LCD flex where it plugs into the logic board, thinking maybe some LOCA leaked into the case. The logic board and case are totally LOCA-free, new battery didn't work.
Please help! Not sure where to go besides replacing the LCD, but I'd like to avoid that cost.
Thanks in advance!
Just tried taping the chips with captains tape. That got it starting up again but its still periodically acting up.
by Cid
