Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Logic Board Fix - Wifi Antenna Faulty - Broken piece
I broke a little piece of the Logic Board, near the 4,8mm Philips Screw, and since that moment my Wifi connection has become terrible, i had to be near the wireless router in order to get connected.
I tried to change the EMI shield, but with no success.
Could that little gold piece have damaged the wifi reception ?
Is this fixable ?
Thank you very much for the support.
Score -1
Add a comment
Chosen Solution
Andrea, yes it could be a big issue. That "little gold piece" is part of your "ANTENNA MATCH AND FEED" circuitry. It is reference designator SP2_RF and check the attached schematic. The only way to fix it would be to somehow get a contact point to connect to the logic board and the opposite mating area.
Score 1
Add a comment
Hi
Can you please indicate where the image where the motherboard is broken?
2 Comments:
Basically if you have an absorption problem is related to wifi antenna is in black and at its end there is a connection silver color.
You can easily recognize it, what keeps the silver connector, it is the longest screw in the black antenna (looks like a black Plata is also pressuring the connection screen) and a long screw that holds the silver connection is very small, he may have fallen or have not closed the screw hard enough.
here is the pic wifi iphone 4
by
HI, thank you for your reply, I just submitted the image where there is the broken horn.
I do have the EMI shield with the silver connection, i replaced it twice and I didn't solve the problem.
by
Add a comment
Add your answer
Andrea will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 351
