Display not working after replacement
I just replaced the display. I plugged it in and it worked. Removed it, installed the digitizer and replugged the display and now the display won't come on
Try a reset. Hold down the power button and the home button simultaneously until you see the apple logo. If this doesn't work, you likely blew a fuse. You can google the fuse locations and replace it or bridge it with a bit of solder. Good luck!
Hi,
Wait until the battery is discharged. This can happen if you remove the display before power off the device.
Regards.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 173
