Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3215 Questions View all
Replacement, broken pin of speaker enclosure
Hello,
During the replacement of the screen of my iPhone 4 I broke a pin that connects the dock to the battery (Speaker enclosure ?). See image : http://d3nevzfk7ii3be.cloudfront.net/igi... and http://d3nevzfk7ii3be.cloudfront.net/igi...
You know it has 4-5 pins... And I broke one. The iPhone is still charging. But is this serious ? For the battery ?
Thank
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
I believe the pin you're talking about is part of an antenna so it might affect your signal.
Comments:
Missing one of those four pins will not cause any problems. Be very careful not to damage the others. As iDoctor says they are antenna pins, and have nothing to do with battery or charging.
by
Thank you !!
by
Add a comment
Add your answer
Panama will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 108
