Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
iPhone 3G moving memory to another 3g, white screen problem
I have an old iphone 3g which had the white screen problem
But i tried many times all the possible solutions like pressing home+power buttons but it keeps showing the white screen
I even took it to an apple repair shop but they told me it couldn't repaired !!
Now i want to access to an importants notes and photos in the iphone
What im thinking is to buy another used 3g and try to move the meomry from old one to the new one
And then i have the accses to my needed notes
Is that possible ? And how can i do it ?
Or any suggested solutions please ?
Thank you.
Score -1
3 Comments
Is your iPhone still recognized by iTunes on a computer? If so are you able to successfully back it up via iTunes?
by
I formated my laptop so it is not recognized by itunes
And it ask to open the passcode but the iphone has the white screen i coudnt write if
by
Couldnt write it*
by
Add a comment
1 Answer
Most Helpful Answer
The storage portion of your iPhone is part of it's logic board, meaning you would need to move the entire logic board over to the new iPhone. This is possible though the problem I would be leery of is that your logic board might be causing the white screen.
A quicker/easier solution would be to remove the display assembly from the good/working iPhone 3G and install it on your current iPhone 3G. If the display is the problem on your old iPhone then this will fix it and you'll be able to retrieve your information. iPhone 3G display assembly replacement
If the display doesn't fix it then the logic board is the next likely culprit. Moving it from your old iPhone to the new one would only bring the problem along with it. Hopefully this isn't the case since the logic board contains your data.
I had asked about an iTunes backup because, if available, you could simply restore the backup to the spare iPhone. With the iPhone being locked and the screen being white I don't believe this is an option with iTunes. You might look into iExplorer and similar products to see if they allow you to browse a locked iPhone in real time.
Good luck!
Score 1
Add a comment
Add your answer
Fatma will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 160
