Ipad mini wont charge after screen repair
replaced digitiser all working perfectly - but wont charge with known working charger/s...tried 3 different chargers.
Well if u have tryed another charger or cord,and u no that aint the problem,and wrk was done recently,could of left something inside unplugged,it can happen,must take aprt and see,or if done at a shop ,call them tell them whats up,make sure port were u connect charger is tight and not loose,or moving alot,could be charger or one side broke off motherboard and may need soldering,k,but goodluck
I repaired it - but I'm a repairer, with many years ex and many hundreds of devices repaired. nothing unplugged inside. wont register when plugged into macbook also doesnt charge.
Check for missing small resistors near where the battery connects to the logic board. They can very easily be scraped off even with a finger nail while you are disconnecting the battery. If so, you likely will not be able to find the resistor. As a last resort, you could try bridging the two points with a solder ball.
Michelle is correct there is a resistor right next to the battery port that probably got knocked off. I'm having the same problem.
Battery says charging but remains at 1% after digitizer replacement
Hi there
i think i found this proble and have been able to take a picture of this. I have the same problem and need to find out if there is a posible way to solder this my self.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 1,133
