Televisions made by the Chinese multinational electronics company, TCL.
264 Questions View all
Question Closed
Coax input died...can I repair/replace part or work around?
I purchased a refurbished TCL LE39FHDF3300 39in 1080p LED HDTV tv and the warranty is out. Last week the tv starting making a popping sound when we watched tv...did not do it when watching Roku. The next day I had no input on the tv side...Roku still works fine. I hooked up a portable tv to the coax and it worked ok...but have a blue screen/no signal on the TCL...so I assume the coax input is dead. Are there replaceable parts in the TCL to fix this problem or do I need to purchase a demodulator and use the AV input for my tv watching? I had an analog pass-through DVT converter box and attempted to do the work around but all I get is a weak signal message.
My tv is connected to a Dual Satellite box from DISHNetwork a VIP222K and is operating as TV2
2 Comments
Sounds like some caps on your AV board went out. Have you tried to input your VIP222K YPrPB cable or RCA/S-Video to your TV. that should bypass the coax altogether.
by
All other inputs seem to work, but I have RG6 installed coming from my Sat box in the living room and running a 60' RGB cable is not an option...was wanting to use the existing coax and use some type of converter to use one of the other inputs...something relatively inexpensive.
by
Add a comment
1 Answer
Chosen Solution
Lee Colley, in that case the only thing I know of is a RF Coax To RCA Composite Video Audio Demodulator. something like this should work. There might be cheaper ones available. Why not take a look inside your TV and see what it needs to repair. Hope this helps, good luck.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 284
