Can I repair the inverter?
Is it possible to repair or obtain the inverter board for the Cinema Display?
Can you send the screen back to Asia where it was manufactured?
I can (just) see the digital information on the screen and the main output board seems OK.
I think it is the inverter which is attached to the back of the screen panel that has failed.
7 Comments
No you don't need to send the part all the way back to Asia.
by Dan
I bought the unit with the fault... standard UK electricity . Can I buy the little logic board that is fitted to the back of the screen ? or repair it ...are there any circuits available, is that logic board specific to that display ? Peter
by Peter
What exactly are you seeing when you say "I can (just) see the digital information"?
by oldturkey03
If you shine a torch at the screen you can see the digital imagec ,,, but thereis no backlight illumination
by Peter
Looking at the logic board you should see a larger rectangle connector on the right edge marked converter. This is the connection for the screens LED back lights. Make sure your connection is firm and the wires are not damaged. If this looks OK the power services on the logic board for the LED's needs to be diagnosed at the circuit level which I will assume here you are not equipped to handle. You could just have a fuse link blown or it could be deeper.
by Dan
Show 2 more comments
