Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
2nd Top Case Install, Damaged DC-in Plug on Logic Board. FIXED!
Third attempt to get my water damaged MBP 13 Mid 2010 going.
1. I cleaned logic board after water damage as suggested from my first post. MBP started but trackpad erratic, some keys didn't work and power button did not work.
2. Installed first replacement upper case as suggested in my second post. MBP worked fine except for power button and need to jump start.
3. Installed second upper case today and can't get it to start. I checked the battery level before I did the install, and I had used the MBP earlier today. I saved all my data, closed all my applications, and shut down. I disassembled from 1st upper case and reassembled into replacement upper case. I closed it up and tried to power up. No luck, so I tried to jump start it and nothing happened. I then checked battery power and nothing. I connected mag safe charger and no light and unable to jump start.
I looked through the forums and rechecked all my connections twice. I checked my dc-in board's wires to make sure they weren't damaged / broken- twice. Tried to do the SMC reset several times. I'm not getting anything. Could I have shorted the battery or mag safe? As it turns out, I bent the pins when I was checking DC-in board. The two pictures show the connector, located on upper left corner, above speaker. Other photo is from top view, looking into connector.
Here are the pictures of my fix. I trimmed a bit of the casing with a razor blade because I couldn't get to the pins with forceps or a paper clip. I used a sewing machine needle(?) that was lying around to move the pins enough to use a spudger, paper clip, and the tweezers from the ifixit tool set to straighten pins. This also helped insert the DC-in board connector more easily. The fix worked. MBP is now charging. Thanks to all for your help.
Score -1
4 Comments
Update: Triple checked again today because I scheduled an Apple Genius appointment for tomorrow Friday. The fan was disconnected. I reconnected and jump started. Signs of life! Battery symbol has an X, mag safe not lighting up, battery indicator not showing anything, Coconut Battery does not show that I have a battery. Fan has been running continuously since I turned MBP on. But the computer is on and I am posting this with it, so maybe there is hope....
by
Update # 2: Reset SMC, fan works normal now, battery icon correct and shows up on Coconut Battery. Mag Safe light not lighting up, battery indicator working. Power Button works. Feeling hopeful.
Thanks for the support.
by
Update # 3: Got my computer back from Apple Store and diagnosis of bent pins in DC-in / Mag Safe charger. Pins are bent on the part attached to logic board and would cost $750 to repair. I elected not to repair MBP. I am currently using my MBP after having powered it up. It is working, however, the battery indicator shows that it is "Not Charging". The battery charge has been holding steady at 91% for the last hour with the Mag Safe charger plugged in. I notice that the display dims when I remove the Mag Safe charger. Any thoughts?
by
DSCantu, great job in getting it done. best of luck to you.
by
Add a comment
Chosen Solution
If I understand your last update you need a new DC-in board, which if you are willing to DIY you can replace for a lot less than Apples' quoted repair price. This is an advanced DIY repair.
Only you know if you can DIY - or pay someone less than Apple wants to do the repair.
If you are going to DIY obtain all the recommended tools, study (not just read)the guide before beginning. Keep track of all the screws
Good Luck.
If this answer is acceptable please remember to return and mark it.
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board Image
Product
$9.99
Score 1
2 Comments:
Machead3, the socket on the logic board is damaged. It has bent pins which do not allow the DC-in board connector to go in correctly. Apple said they could not straighten the pins. Can this be done?
At any rate, the MBP is working and the battery holds its charge as long as it is plugged in, but does not charge up to 100%. My concern is what will happen when the battery goes to zero.
So, how to fix the pins on the logic board without having to replace logic board, or how to charge battery via another means if needed?
Thanks!
by
DSCantu, post an image of your connector with the bent pins. Add the photo to your question. Adding images to an existing answer That way we all can see what you see and how bad the damage is.
by
Add a comment
DSCantu, looks kind of bad;-) No matter how you look at ti, that connector does not work the way it is. So, you could try and move the pins back up with a pair of small hemostats and a needle or some other small instrument. Biggest issues here is that they can beak off due to metal fatigue. If that does not work, you may have to solder a new connector to the board. The connector itself is a Molex 78048-0573. If you can not find the right connector, you could have someone solder the DC-in board cable directly to the rear contacts on the connector. That would obviously be the last and least best solution. Hope this helps, good luck.
Score 1
2 Comments:
Oldturkey03, I am going to try to straighten pins. Thanks for the part # and the tip.
by
Thanks to Oldturkey03 for asking for photos. This prompted me to dig into the socket to straighten pins since I had to open MBP again and remove logic board. I will post photos of successful fix.
by
Add a comment
Add your answer
DSCantu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 475
