replacing the Hard Drive with a SSD
Is is possible to replace the 1tb hard drive with a Solid State Drive? and what parts would I need?
You may want to consider augmenting your system with a second drive. In this case adding the SSD Vs replacing your current HD. Here's the guide to do that Installing iMac Intel 27" EMC 2390 Dual Hard Drive Kit,
If your current HD is having problems I would still setup the dual drive setup and take the time to replace the HD at the same time following the link in Igors' answer.
In either case you'll need an external FireWire HD or USB thumb drive to boot your system (if you don't have your OS install CD/DVD) as well as make a backup of your current apps & files.
It is possible, yet not very straightforward: iMac Intel 27" EMC 2390 Hard Drive Replacement
Since your iMac mounts a 3,5" hard drive, you'll need a 2,5" -> 3,5" adapter for your SSD.
While they are harder to find (and more costly) you can get a 3.5" SSD. If you do get a 2.5" be careful on the adapter frame type some won't fit very well.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 708
