Model A1288 / 8, 16, or 32 GB capacity
451 Questions View all
Replaced battery and now touch screen is non-responsive, why?
I plugged my iPod into the wall and it turns on just fine but when I take it off the power shorts out. I replaced the battery and now the iPod turns on but it doesn't respond when I go to unlock it. Did I forget to connect something inside the iPod?
Score 1
Add a comment
Most Helpful Answer
to answer your last question - yes - i think so.
the connector for the touchscreen is n the top left, since it is so small - there is no real "feeling" about plugged or unplugged
open it again and check the connection (see step 8) - thats the connector
Score 1
Add a comment
I had the same issue. I know the connector was nicely seated, because I lined it up carefully and it snapped easily into the socket. However I had torn the front panel ribbon cable on disassembly and didn't realize it. So, now I'm ordering a new front panel assembly. Luckily the entire fix is still close to what a factory repair would cost and I have gained the experience from my disassembly mistake.
Add a comment
Add your answer
warnerd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 2,798
