Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
Question Closed
LCD Replacement iMac 20"
Can you replace a LM201W01 (SL)(A3) with a LM201E01 (ST)(B2) or LM201W01 (A5)
serial CK6321E7U2P iboght a imac with no lcd .chimes reset pram .all fine it boots up till os login.
but i dont get picture on lcd.via dport on to hdmi
excellent job all on its best.
i got 2 diff tft for imac and 6 diff.kables here all shure working parts.
i need # for cable if for inverter & lcd
4 Comments
Intro Date: January 10, 2006 Disc Date: September 6, 2006
Order No: MA200LL Model No: A1174 (EMC 2105)
Subfamily: Early 2006 Model ID: iMac4,1
Std RAM: 512 MB Std VRAM: 128 MB
Std Storage: 250.0 GB (7200 RPM) Std Optical: 8X DL "SuperDrive"
by
Thx
can you help me again,-)
Ihave two iMac Intel 20" EMC 2082 serialW85523RWTAR and serialW855231JTAR
Diagnostic for both is same no chimes but all 3led green .ithink idont came further
cause i dont use the right parts .
LVDS cable part number is ?
lcd part number ?
inverter part number ?
by
Does this look right:"
2.1 GHz PowerPC 970fx (G5)
Intro Date: October 12, 2005 Disc Date: January 10, 2006
Order No: MA064LL/A Model No: A1145 (EMC 2082)
Subfamily: iSight Model ID: PowerMac12,1
Std Storage: 250 GB (7200 RPM) Std Optical: 8X DL "SuperDrive"
by
If the above specs are right then the parts are as follows
Display Panel, LCD 661-3779
TMDS Cable 922-6986 no LVDS
Inverter 661-3781
by
Add a comment
1 Answer
Chosen Solution
enricosucca , it looks like that you can use (SL)(A1) and (B5) as a substitute. The (A5) will not work. The inverter cable is part of the inverter part number 661-4112, the LVDS cable is part number 922-7251. Hope this helps, good luck
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 353
